Sony 42in xbr flat screen user's manual How do I turn on the port on the left hand side of the sony xbr flat screen tv?
  • 10,594 Answers
Let me know exact model of your TV and do you see any label on subject port that you want to turn ON, how it looks like?
Posted on Jan 18, 2010
SOURCE:
Hoow do I connect sony xbr trinitron TV to HDMI cable.
Refer its user manual for details. If you do not have the user manual. try the site linked here, and download it for free. www.retrevo.com/
Electro help
Sep 12, 2014 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Our Sony XBR Triniton shuts off and the standby light turns on however no picture or sound on television.
You do not have its user manual with you I assumes. Click here to download the user manual to your TV. Refer it. It will have all details you want to know.
Jul 26, 2012 | Televison & Video
When we turn on our tv in the morning the left
Call Sony my friend. I have the same exact issue with the same model. They already have a recall for the 46"XBR4. Let Sony know that us 52" owners are having the same issue. I'm essentially calling them everyday until they fix it.
Mar 27, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a sony bravia xbr 32 inch and the picture is only on half the screen
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Oct 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
BRAVIA - Information bar on top of screen won't go away
You can turn off the information display using the user menus.
also hitting the display button should make any and all OSD information go away.
Jul 09, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
I get a thin line of distortion on my sony xbr 42in
Your format is wrong. Make sure that your tv is in full mode and your direct tv is in 1080i stretch mode. This should correct the problem. Also, WB is having problems. This is common on their channel. If it is happening on any other channel, try the above. Hope this helps. JOHN
Feb 27, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Where do I find the place to connect headphones on the bravia xbr
Try this: face the television; Left hand side on the edge; Look for the green input port (top hole); plug in headphone jack; should work
Dec 22, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Ekse
