To set the alarm, press the lower left button until "AL" appears.
Press and hold the center right button until the time digits flash.
Use top or bottom right buttons to set the time.
Press the center right when you have done setting the time.
Press the center left button to start or cancel the alarm.
The alarm will sound for 30 seconds; Press any button to stop.
Te alarm will repeat daily until it is turned off.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
