LANIER 5618 COPIER ERROR CODE SC-320
WHEN TURNED ON WILL GO ERROR CODE SC-320, HAVE BEEN TOLD THIS MAY BE A SCANNER ERROR OR POSS POLYGON MOTOR ERROR??? I OWN AN OFFICE REPAIR COMPANY, THIS ERROR IS A NEW ONE!!
  • Anonymous Mar 20, 2014
    there is apiece of paper and i take it away then this error appear please help me
  • Anonymous Mar 21, 2014
    error code sc 194
    Scholar:
  • 78 Answers
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Posted on Feb 12, 2008
SOURCE:
What is the solution of error code sc220
Sc 220. For the earlier model..it refers to the polygon motor error. U cannot clean the motor. U have to replace it. Becauce the sensor did not detect suficient optimal RPM
Aug 17, 2014 | Ricoh Aficio Mp5000 Lanier Ld050
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
Error code sc 320
polygone motor error in laser unit change it possibe causes cutting wires between polygone motor and ld unit
Jan 06, 2011 | Ricoh Office Equipment & Supplies
Lanier 5518 gives a SC320 error code
This SC-320 code error occurs when polygon mirror motor fails or poor connection between BICU & polygon mirror motor please check first the connector of motor if you feel that the connector is good change the polygon mirroe motor it sits inside the LD unit please call the expert to change the part
thanks
Dec 15, 2010 | Lanier Office Equipment & Supplies
Aparece el error SC 320 que puedo hacer??
320
Symptom
Polygon motor error
The polygon motor does not reach its operating speed within 10 seconds after the polygon motor on signal, or the lock signal is not detected for more than 200 ms continuously during operation.
Possible Cause
• Polygon mirror motor defective
• Poor connection between the polygon mirror motor driver and the SBCU board
• SBCU board defective
Nov 13, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Error code sc320
sc code 320 laser unit faulty polygon motor try lubricate bushing if still codeing out replace polygon
motor
Nov 11, 2010 | Ricoh Aficio MP 1600L Black and White...
Can i reset the error code sc 320
sc 320 is the laser error. the polygon mirror motor is faulty in laser unit and it can only be solved by replacing the polygon mirror motor. there is no other solution.
Oct 12, 2010 | Ricoh Office Equipment & Supplies
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
1,303 people viewed this question
k24674
Marvin
Marvin
