usually means that there is a blockage in the travel area of the fan intake if you cannot see any blockage then regretably it would have to be a service call due to having to disassemble or replace the board that controls the motor control. also could be a sensor but more than likely a blockage.
If you can have an electricain check to make sure the wiring is all good that would be a start. It is NOT uncommon for a wire to come loose. If that is OK then you need a new fan. If the fan is not working or working properly then the unit will not work at all. With out the cooling fan the oven could overheat and start a fire.
See Page 8 http://www.dacor.com/Dacor.Website/WorkArea/showcontent.aspx?id=1297
1. ERD models must be connected to a grounded,
metallic, permanent wiring system. Alternatively,
a grounding conductor should be connected to
the grounding terminal or lead on the appliance.
2. ERG models must be connected to a grounded
receptacle. Failure to do so may result in an
electrical shock hazard.
3. Do not use an extension cord with this appliance.
Such use may result in fire, electrical shock, or
other personal injury.
4. Do not install a fuse in the neutral or ground
circuit. A fuse in the neutral or ground circuit may
result in an electrical shock hazard.
