Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Feb 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I got my new Motor Conversion Kit today through the mail but it didn't include the instruction sheet on how to install the new motor and board. Can't figure out how new wiring harness on the motor is supposed to connect to the control board. Anyone have a copy of the instruction sheet? The instruction sheet is Maytag Part #16022060.
  • 3 more comments
  • ppost02 Feb 11, 2008
    My model is MAH4000AWW.
    Posted under wrong area by mistake.
    Uhhh, what you sent me doesn't help. I need to know how to install the new motor and board. I cannot see any place where the new wiring harness on the motor connects to the new board.
    Ooops, sorry. Guess I should have read the email first, not just the attachment.
  • ppost02 Feb 12, 2008
    Thanks sooo much! Got it back together and haven't washed a load yet but seems to be working okay. I have never seen a plug connected to a circuit board that way before. Wished I would have taken other posters advice about the mounting bolt ... my thumb is sore but I finally got it in. Thanks again.
Anonymous
Level 3:
  • Master 770 Answers
  • Posted on Feb 11, 2008
Anonymous
Master
Level 3:
Answers
770
Questions
Helped
474897
Points
1794
I do please post your email here and i will send it to you
  • 2 more comments
  • Anonymous Feb 11, 2008
    one thing you have the model listed under a MAH5500 but you say you have aMAH 4400 what is the complete model # i see to diffrent versions here and want to get you the right one
  • Anonymous Feb 12, 2008
    Check your email now
    Great Glad to Help
  • jim racine
    jim racine Apr 18, 2014
    Gary, can you send the instructions for mah3000aww to [email protected]? The #'s on the instruction sheet for this model are 16022060 and 6 2727880. Thanks in advance.
2answers
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
1helpful
Maytag Neptune MAH5500B Washing machine
Usually, the LR or 'Locked Rotor' indicates a problem with the motor / motor control board or MBC. The MBC is located near the floor on the right side. See www.neptunehelp.com for disassembly photos. The original MCB's had a high failure rate so Maytag redesigned the MCB and the motor. The motor conversion kit is part number 12002039, which includes the new motor, MCB, harness and takes about an hour to install. You can inspect the MCB for either a blown 10 amp fuse or if you see components that are burnt or discolored. If either of these is the case then you will need the motor conversion kit.
In addition, as your Neptune ages you might notice the spin cycle getting louder to where it will sound like a jet plane taking off. If this is the case then you can replace your bearings and seal kit. See www.neptunebearing.com. You can also rent a special Neptune bearing tool called the tony tool which includes the use of a DVD that shows you how to take apart Neptune, replace bearings and install the 12002022 seal kit. I hope this helps...
MayTag Neptune to Propane
buy the lp conversion kit from one off the links here at fixya and it comes with instructions
go to sears.com to get the conversion kit which will contain detailed instructions.
2helpful
Maytag Neptune
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
1helpful
2answers
I press the start button, it starts to fill then shuts off after a few seconds. If I go to drain cycle, I press the start button, it begins to drain the shuts off after a few seconds. No noises or...
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness. This kit takes about an hour to install. See www.neptunewaxmotor.com for step by step pictures on how to disassemble your Neptune.
Need instructions for motor conversion kit for maytag neptune mah300aww
they come within the package when you recieve the conversion kit
.. if not contact where ever you purchased it and have them get to you
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
