Dishwashers Logo
Anonymous Posted on Jan 18, 2010
GE Dishwasher no water upon start, humming, blinking lights
GE Dishwasher - no water running upon start, humming, blinking Lights on Control Panel and beeping. Tried the reset, didn't work, shut off circuit breaker for awhile, turned back on. Dishwasher did not reset lights still flashing & still beeping and if close the door, it still hums but still no water.
  • Anonymous Jan 19, 2010
    I tapped on the float, removed the lower blade to see if there was debris, none found, pour a small amount of water in there, replaced blade. Turned circuit breaker back, closed d/w door, lights were blinking and a few small beeps, machine was running with no water; after 90 seconds the machine reset and the problem was resolved. I was able to run the dishwasher normally with no further incident. Thanks for all the help.
Joe Lishman
Level 2:
  • Expert 192 Answers
  • Posted on Jan 18, 2010
Joe Lishman
Expert
Level 2:
Answers
192
Questions
Helped
98960
Points
451
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
My hanseatic dishwasher is beeping and flashing on the little glass symbol and it stopped working.
https://removeandreplace.com/2015/12/21/dishwasher-has-beeping-sounds-blinking-lights-how-to-reset/
Dishwasher lights flashing or blinking. The heating element heats up the water to operating temperature. If the water doesn't reach the proper temperature after a set amount of time, a light on the control panel might start flashing. ... If the drain pump is not working, a light on the control panel might start flashing. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/28---/Dishwasher-Lights-Flashing-Or-Blinking
Flashing lights and or beep sounds can mean the dishwasher problem was from a power surge or power outage. You can unplug the dishwasher from power or shut off the breaker to the dishwasher for 1 minute. This may reset the dishwasher and get it back to working order.
May 12, 2020 • Dishwashers
My FINLUX C13 reset button keeps flashing and cycle stops wat could be wrong and can I fix it myself, thank u
https://www.youtube.com/watch?v=5-aH_tVbYi8
Apr 17, 2020 • Dishwashers
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Dishwasher starts in any type of cycle, runs for a minute, then shuts off as the lights blink out.
in general your wash motor can cause that. It gets old and you can hear the wash motor making a rumbling noise when it turns on. The increased load with cause a thermal coupler to turn the unit off.
3answers
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Miele g892 scu plus, about 5 years old. when on, all it does is run some motor (humming sound) and flash salt or intake/drain. No program lights on. Sometimes can be reset so rinse light comes on and...
The water in the pan is what is causing the issue - need to find the cause of the leak - door seal or pin hole in a hose - possibly a leaking pump
1helpful
7answers
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
3helpful
Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
