HP Paviilion ze2000 Laptop won't turn on. The battery has been poor for a while (about 10 mins charge) but now won't even turn on when plugged in. There are no lights coming on at the front of the laptop
Remove the battery. It may malfunction now. Turn on the laptop with adaptor power without battery. It should work. If the lap is not still working, you have to check the adaptor, then mother board
Have you tried removing the battery and seeing if the laptop will then run?
Gently wiggle the power supply cord where it plugs into the laptop. These units are known to have a problem with the power supply plug being loose. If the battery only had 10 minutes of juice then it sounds like you must have been using it with plug in power supply, and if the laptop is moved around while plugged in it could develop this common problem. My ze2000 is four years old with no problems, but it has always remained in one location.
