does laptop work without external power supply,if no then Battery probably not charging Dell computers don't like oem power supplies as often need specific dell charger to suit model laptop so that laptop will recognise it and allow battery to charge
The flashing blue light indicates the battery is nearing full charge. If the light is continuing to blink when you reach 100%, I believe this is an indication that the battery is beginning to fail and will not hold a full charge.
The majority of laptops will display a solid green, blue or
purple battery light to indicate that the battery is fully charged. Most
manufacturers indicate that a laptop is in the process of charging by
displaying a solid or blinking green, orange, blue or purple light. If
your battery indicator light is green, blue or purple, the battery is
probably functional, regardless of whether the light is blinking. If the
light is solid orange, the laptop is probably in the process of
charging.
Battery Error Coneventions
Many battery manufacturers use rapidly blinking lights to
indicate that a battery's charge level is low. In general, a laptop will
rapidly blink orange or red when its charge drops below a certain level
until the computer is plugged into a power outlet and charged. If your
laptop's battery indicator continues to blink rapidly in orange or red
or if it remains red even when it is plugged into the charger, it
indicates a problem with your battery or the charger.
please read and execute the commentaries. God bless you Charging Conventions
charging.
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
It depends on the model, however blinking orange is common for charging. Normally Red is critically low battery, orange is low battery power, blinking orange is charging, and green is charged.
Hi there. Sounds like the battery could be faulty. The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery If an AC adapter is not connected to your computer, the computer's power source is a battery. If the battery indicator flashes amber or is a steady amber, the battery needs to be charged. If the battery is flashing green and amber, the battery may be defective. To troubleshoot this problem, use the following procedure. 1. Turn off the computer and peripherals, and disconnect them from AC power. 2. Reseat each installed battery by removing it and then replacing it. 3. Turn on the computer. Does the green power indicator light up? Allow one minute for the computer to initialize its components before checking for signs of power. Yes. Continue to step 4. No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter." 4. Does the battery indicator flash amber or show a a steady amber light? Yes. The battery needs to be charged. Go step 5. No. Go to step 7. 5. Connect the computer to AC power, and fully charge the battery. For instructions, see the topic titled "Charging the Battery" in the online System User's Guide. 6. As the battery charges, does the green battery indicator light up? Yes. Go to step 9. No. Go to step 7. 7. Is the battery indicator flashing green and amber? Yes. Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery. Continue to step 8. No. The problem is resolved. 8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber? Yes. You may have a defective battery. Continue to step 9. No. The problem is resolved. 9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing? Yes. You have a defective battery. Continue to step 9. No. The problem is resolved. 10. If a spare battery is available, fully charge it, and then install it in the computer. 11. Turn on the computer. Is the power indicator off? Yes. Your original battery is defective.
