The RF jack is solder directly into the tuner module and as long as it
did not break the circuit board inside that it connects to, it can be
repaired . Takes a lot of heat though to solder the jack to the
frame of the tuner. Sometimes I use 2 irons to get it hot before
the plastic guts of the jack melt too bad. Also is sometimes hard
to cram the jack back into its mounting hole, may need to file it
out some. The makers don't solder these on they are just pressed
in and crimped which is why they break off so easily. I recommend
using the push on type cables to avoid this problem. Don't forget
to solder the center conductor into the tuner board.
Hope Ya Fix It!
If you have other inputs besides coax in on the back of the tv, use one of them. this is assuming you are using a cable box. hook up the red, white & yellow from the cable boxes audio/video out.you would just have to put the tv on a aux/line in or video input. if you are not using a cable box, you can use a vcr. hook up the coax in, then the rca audio/video out to your tv. this would probably be an easy repair for a pro. you can call one for an estimate since you know exactly what is wrong, but why spend the money if you have other inputs.
hope this helps.
wg
