SOURCE: MY SONY BRAVIA 32" CRACKED LCD
Unfortunately in most cases the cost to repair the tv is not worth it. The replacement panel plus the labor in most cases cost's more than what the tv cost you to buy. You can call Sony if you are intrested in the cost of the panel. 1-800-222-7669
Good Luck
SOURCE: Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
SOURCE: lcd felloff wall-has sound-cracked looking picture-can it be fixed
Yes it can be repaired,but it will probably cost less just to replace the whole thing.
SOURCE: Sony HP1080p Bravia 46 in Cracked Plasma Screen
Typically the replacement panel is too expensive to replace. If you can update this with the model number of the set, I will post the part number and cost so you can make your own decision.
Thanks,
Dan
