I have a new Maytag Bravos washer. Several clothing articles have overflowed and are between the inner basket and outer basket causing an LD error because of the drain plugging and the water not draining. How can I raise the upper lid to access the clothes? Thanks. Very Frustrated with the design.
This is for several brands ... not just the Bravos.
Based on your description, it looked like you needed to take the center agitator out first .... to then access the inner basket bolts ... remove the inner basket to then get to where the clothes are ... not a real easy task
Good luck on your troubleshooting
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
SOURCE: Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
