52HM84 Toshiba DLP with apparent failed lamp (solid red led, flashing green, resets 8X - sound and no pix). Replacing lamp and ballast did not fix. Found 311VDC coming in to ballast. Suspect receiving faulty ballast from vendor.
There is a 5 conductor cable going from a sub board to a module on the light engine - does this have any signals to shut down the ballast?
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
did you happen to find the specs for d3 ande d5????
