One of my friends had a amp like that , i looked at it an the inside of speaker box wires was touching , if thats not it then check ur power an ground , power wire must be the same size ground an if ur ground is not grounded good then u will get the cuting out .
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did! 800 225 5689 - MTX Customer Service & Amplifier Service Center Good luck !
Crutchfield doesn't list the amp at all and SonicElectronix shows it as "discontinued". I'd recommend going to MTX's contact page and ask them directly. They'll usually respond within a day or two.
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
