Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
That's is hardware problem. Buy new motherboard and this will solve your problem
People think it is the power supply but it is not. Replace the motherboard and this problem will fade away. http://www.ifixit.com/Guide/Repair/Installing-PlayStation-3-Motherboard/3493/1
Hi there. Soon as the pilot switches off (will still be red hot but fade away rapidly) the gas valve should turn on. (make sure gas supply is on) If valve doesn't turn on, check sensor located very near pilot element. When the sensor "feels" the heat of the pilot, it switches the pilot off and the gas valve on. Thanks Paul
Hi We've been seeing alot of the HP Color Laserjet range of laser printers coming through with a "prints lightly with red" or "red is faded" fault report, we've been able to resolve the problem mostly by cleaning the scanner. Misalignment is normally resolved therafter by calibrating the machine using its calibration function. (if it has one) Wouldnt suggest this gets tried unless one is familiar with stripping and reassembling these machines though. Hope this helps.
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
