2002 Mazda Protege Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2002 Mazda Protege and have error code P0031 and indicates a Heater control circuit low. I need to know which one is it. Help
Anonymous
Level 3:
  • Master 416 Answers
  • Posted on Jan 17, 2010
Anonymous
Master
Level 3:
Answers
416
Questions
0
Helped
159210
Points
1403
Code p0031 p0037 need see a video how to fix
P0037 HO2S Heater Control Circuit Low B1S2
https://www.obd-codes.com/p0031 Check for a fuse bing blown , Heater circuit shorted in O2 sensor blowing the fuse , maybe . You don't say what make , model an year vehicle an engine size .
I am getting the following codes on my 2002 Nissan Altima v6 3.5 liter P1430, P1420, P1805, P1152, P1102, P1011, P1021 & P1335 I'm going crazy here. Please help!
Definition of Diagnostic Trouble Code P1430 Ford: Electric Air Pump Secondary Lincoln: Electric Air Pump Secondary Mazda: Electric Air Pump Secondary Mercury: Electric Air Pump Secondary Toyota: Intake Constrictor CTRL Circuit Open or Short
Definition of Diagnostic Trouble Code P1420 Audi: Second Air Injection Valve Circ Electrical Malfunction BMW: Secondary Air Valve Control Circuit Electrical Buick: Intake Air Low Pressure Switch Circuit Low Voltage Cadillac: Intake Air Low Pressure Switch Circuit Low Voltage Chevrolet: Intake Air Low Pressure Switch Circuit Low Voltage Chrysler: Register Resonant Charging 1 (RRC1) Dodge: Register Resonant Charging 1 (RRC1) Ford: Catalyst Temperature Sensor GMC: Intake Air Low Pressure Switch Circuit Low Voltage Honda: Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter Jeep: Register Resonant Charging 1 (RRC1) Lincoln: Catalyst Temperature Sensor Mazda: Catalyst system efficiency below threshold (bank 1) Mercedes: AIR Pump Switch over Valve Mercury: Catalyst Temperature Sensor Oldsmobile: Intake Air Low Pressure Switch Circuit Low Voltage Pontiac: Intake Air Low Pressure Switch Circuit Low Voltage Saturn: Intake Air Low Pressure Switch Circuit Low Voltage Subaru: EVAP Purge Control Solenoid Circuit High Input Toyota: SCV Control Circuit Malfunction Volkswagen: Second Air Injection Valve Circ Electrical Malfunction
Definition of Diagnostic Trouble Code P1805 Ford: Four wheel drive high indicator circuit failure Lincoln: Four wheel drive high indicator circuit failure Mazda: (4WD) High Indicator Open Circuit Mercury: Four wheel drive high indicator circuit failure Toyota: SB Solenoid Circuit Malfunction
Definition of Diagnostic Trouble Code P1152 Audi: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Jaguar: Lack of H02S-21 switch, sensor indicates rich Land Rover: Oxygen sensor response time bank 2.Short circuit to ground Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Subaru: Oxygen sensor range /performance problem (Low) Volkswagen: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded Volvo: Oxygen Sensor Front, Bank 2
Definition of Diagnostic Trouble Code P1102 Acura: Mass Airflow (MAF) Sensor Lower Than Expected Comprehensive Audi: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Chrysler: HEV Stop Request Performance Dodge: HEV Stop Request Performance Hyundai: MAP Sensor Circuit Low Input Jeep: HEV Stop Request Performance Kia: Heated Oxygen Sensor Bank 1 Sensor 1 Heater Circuit High Input Land Rover: Throttle to air flow plausibility not active.Last occurrence - minimum signal Mazda: Mass Air Flow Sensor In Range But Lower Than Expected Mitsubishi: Traction Control Ventilation Solenoid Circuit Porsche: Heated Oxygen Sensor 1 Ahead Of TWC Heater Short To B+ Saab: Front Heated Oxygen Sensor Bank 1, Control Module Input, Current in Pre-Heating Circuit Too High Subaru: Pressure Sources Switching Solenoid Valve Circuit Malfunction Volkswagen: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Volvo: Power Stage Group B
Definition of Diagnostic Trouble Code P1011 Saab: Injector Cylinder 1 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 1)
Definition of Diagnostic Trouble Code P1021 Honda: Valve Pause System Stuck On Comprehensive Mitsubishi: OCV OPN. Bank 1 Saab: Injector Cylinder 2 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 2)
Definition of Diagnostic Trouble Code P1335 Audi: Engine Torque Monitoring 2 Control Limit Exceeded Buick: CKP Circuit Cadillac: CKP Circuit Chevrolet: CKP Circuit Ford: (EGR) Position Sensor Minimum Stop Performance GMC: CKP Circuit Infiniti: CKP Sensor (Ref) Jaguar: CKPS Circuit Malfunction Land Rover: Exhaust gas recirculation position sensor minimum stop performance. Lexus: Igniter Circuit Malfunction Bank 2 (During Engine Running) Lincoln: (EGR) Position Sensor Minimum Stop Performance Mazda: (EGR) Position Sensor Minimum Stop Performance Mercedes: CKP Sensor Circuit Malfunction, Bank 2 Mercury: (EGR) Position Sensor Minimum Stop Performance Oldsmobile: CKP Circuit Pontiac: CKP Circuit Saturn: CKP Circuit Toyota: No CKP Sensor Signal Engine Running Volkswagen: Engine Torque Monitoring 2 Control Limit Exceeded http://www.obd-codes.com/trouble_codes/nissan
My dodge durango is showing codes P0031 & P0037. what do i need to do now.
code P0031 - O2 B1 S1 heater circuit low. code P0037 - O2 B1 S2 heater circuit low.
2answers
2003 Lexus GS300 P0031 code
Yes the O2 sensor preheater problem will turn on the VSC light, see the complaint often, why? don't know
.P0031 TOYOTA - Oxygen Sensor Heater Control Circuit Low Bank 1 Sensor 1
In most cases the O2 being replaced cures the code but here is the full story.
Possible causes- Air-Fuel Ratio (A/F) Sensor Bank 1 Sensor 1 circuit open shorted to ground
- Air-Fuel Ratio (A/F) Sensor Bank 1 Sensor 1 circuit poor electrical connection
- Faulty Air-Fuel Ratio (A/F) Sensor Bank 1 Sensor 1 circuit
- Air-Fuel Ratio (A/F) Sensor Bank 1 Sensor 1 circuit fuse
- Faulty Engine Control Module (ECM)
My check engine light has been on for three days and when a scanner was placed on it the following information came-up. Trouble code P0031, H02S Heater Control Circuit Low (Bank #1 Sensor #1). However, I...
I can only help with the code,P0031=Shorted low condition detected in the oxygen sensor,1/1 heater element control feed back sense circuit.
Also a web site which gives the code breakdowns-www.wjjeeps.com/faultcodes.htm.
maori boy
The check engine light is flashing in my 2002 mazda protege 5. what does this mean?
This means an error has been detected by your engine management system. The next step is to pull the error codes from the computer and investigate those indications.
1helpful
I have a 04 sequoia and the codes p0031 and p0051 are coming up. How do I fix this?
Trouble code P0031 means: Oxygen Sensor Heater Control Circuit Low - Bank 1 Sensor 1 .
Error code p0051:replace O2 sensor ($75-150 depending if OEM) before catalytic converter. need O2 socket ($10) to get at and tough to get to if vehicle isn't at least on a ramp.
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
