Garmin Forerunner 305 GPS Receiver Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heart rate not being received after changing battery.
B Highfield
Level 2:
Sniper:
  • Expert 84 Answers
  • Posted on Mar 01, 2010
B Highfield
Expert
Level 2:
Sniper:
Answers
84
Questions
0
Helped
87142
Points
329
I found this on the internet......
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Hope this helps......
3answers
HOw does it start working?
http://www.omronhealthcare.com/media/uploads/hr-100c-instruction-manual.pdf
Here is the link to the owners manual.
How do i change a battery in a garmin 305
Hi David!
From your Owners Manual (Page 54)
http://www8.garmin.com/manuals/984_OwnersManual.pdf
REPLACE THE HEART RATE MONITOR BATTERY
"The heart rate monitor contains a user replaceable CR 2032 battery...
Locate the circular battery cover on the back of the heart rate monitor. Use a coin to twist the cover counter-clockwise until it is loose enough to remove. Remove the cover and replace the battery. Be careful not to lose or damage the o-ring gasket on the cover. Then use a coin to twist the cover back into place."
Hope this helps.
9helpful
Battery change, now no signal
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
Heart rate writst watch won't work
Here is the manual for your heart rate monitor:
http://www.omronhealthcare.com/img/shop/hr-100c---2003-hr100cinst-rev-a.pdf
The size of your wrist shouldn't matter, because you can actually mount the monitor to a bike handle, so you don't have to be wearing it at all. It's just acting as a receiver, displaying the info. Are you wearing the transmitter belt, is it positioned correctly, and tight enough? Are you putting water or gel on the backside of the transmitter so that you get good conduction and contact? Is the transmitter belt within 20 inches of the monitor receiver display?
The transmitter battery might be low. If so, the symptom would be that your readings can be erratic. I know you said that you just bought it, but batteries can be low in new products. ..How many times have you bought a new digital watch only to find that it had a low battery...You can replace the battery in the transmitter with a lithium 3v battery #CR2032. Do you see a low battery indicator? If so, the display (receiver) battery also needs replacing and it uses the same battery as the transmitter.
Hope it helps, please let me know.
Thanks
8helpful
I haven't used my Garmin Forerunner 305 for over a year - but have just started using it again. It wasn't picking up my heart rate from the HRM, so I changed the battery in the HRM but it is still not...
Bpm isn't showed, i have changed the batery and bpm doesn't apear
I just helpped some one else with same probelm, try this see if it works.
Isn't receiving/showing my heart rate
First thought is the battery in the wearlink is dead if you're getting no icons or lights flashing. Luckily the wearlink is designed to have the user change the battery. Ideally your local Polar outlet will sell battery kits (app €12), these come with a new battery, seal and door and take a minute to change. Here in the shop we routinely offer to change it 'cos customers can be a bit wary of taking it apart, but it's easy.
If the shop doesn't stock them they should be able to order it for you..
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
