2 or 4 door? If 2, you should still be able to use key on exterior, and I don't think they have a child lock on 2 doors, so I'm guessing 4. With car unlocked, can't you open rear doors from outside even with child lock on?
You will need someone with a break in kit. You are only allowed them if you have a reason to have them ie: licensed repairer. It will contain wedges to go between the outside of the window & the door to spread the gap. There is then a series of wire hooks, sheet steel with notches cut out etc... They need to put the correct one in the gap & unlock the door if it is locked. Then actuate the latch mecanism inside to open the door. You can then get the trim off to repair the problem. I have a kit but sorry I can't help.
hi if you get a metal coat hanger open it up and put a hook on the end slide it down between the glass and the door by the door catch you should be able to knock the child lock off so you can open the door you have to get this just right and it can be a bit tricky but it does work
lock rods inside the door need to be attached and with exterior door handle broken, it will need to be replaced first. so the assembly will be complete
you will have to take the panel off to see why the inner lock/activator isnt working properly, besides youll have to take it off to fix it anyway.Maybe as simple as a bent handle to lock rod being bent and no longer long enough to activate lock correctly.youll just have to look and see.Let me know what you find
the assy. that keep therod for openeing the door up is whats wrong worn out needs replacing , yu will have to take panel off to repair though good luck
