Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Have you cleaned the dryer? You should clean out the heating coil area at least once a year. Lint can build up and burn and the odor is drawn into the dryer when it runs.
I run the dryer and after it finishes I get a gas smell and will disapate after
