Computers & Internet Logo
Posted on Jan 17, 2010
The Speech Component isn't working but the
The Speech Component on my Rosetta Stone isn't working but the microphone on my computer is. I don't know how to fix this
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12715
Points
Ok I have a solution for my laptop. I have Laptop with realtek HD Audio and Windows 7. Rosetta stone did detect the integrated microphone at first, but then nothing helped to do this again. So I decided to upgrade audio drivers. First installer removed old drivers and asked for reboot. I rebooted and DID NOT INSTALLED DRIVERS. Windows installed its native drivers and here we go. I have been learning Japanese for two days already :)
So the solution for windows 7 is:
1. Remove your audio drivers
2. Reboot
3. Wait until windows install its own drivers.
4. Learn languages.
Rosetta stone microphone
You can try buying a high grade corded microphone or head set that plugs in. It also depends on the computer speed. old computers don't have the power to process the speech data.
Rosetta stone error 1117 with access to internet
temporarily disable avast and try it again. if it works it is a AV setting, otherwise maybe your internet provider is blocking. Remember to re-enable avast as soon as possible
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Problem: Rosetta Stone msg: 1117 error occurred in the speech component operating system: Mac OSX Hi, I Have Rosseta Stone installed on my macbook pro (osx) and have/used it over a week now....
Try my steps:-
1.If you know removing installed programs from MAC, then please remove this application named-Rosetta Stone.
2. Now, remove all the cables & wires if your hardware audio device & turn off your computer.
3. Reconnect all the cables & wires & start your computer.
4. This time, reinstall the audio driver.
If this doesn't work, then you may try these ones:-
METHOD 1: Perform Step 1 to 3 again & install a different audio driver instead of Rosetta Stone.
METHOD 2: (This is only if METHOD 1 is also not working) Try your mic in any other MAC by installing Rosetta Stone in that system.
Note: You may search for a different audio driver at http://www.download.cnet.com/. Here search in mac column.
For any more support or any questions in future, you are the most welcome to contact me at [email protected].
3helpful
I fave a microphone in my web camera. And Rosetta Stone detects it. But I can't pass the microphone setup before a leson. I can speak for hours, but Rosetta Stone doesn't stop the checking. However it can...
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
63helpful
3answers
Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Mac computer doesn't hear voice when using rosetta stone
I have windows, so I don't know if this will help, but I found that you have to make sure that the recording device is named "Microphone HS" or something with the word "microphone" in it. For some reason, rosetta stone does not recognize recording devices unless they have the word "microphone" somewhere in their name.... This is true for windows, I don't know if this is true in Mac. At least this may point you in the right direction. :)
16helpful
RS V3 Error 1117 - does not detect microphone
I have finally found a solution! I found it by chance on the rosetta stone troubleshooting page. I have nod 3 antivirus + firewall and in the firewall settings the rosetta stone application was blocked (it was denied internet access). I just deleted it from the list and the next time rosetta stone asked for internet access I clicked yes. Now rosetta stone detects both my dynamic microphone and my usb headset and it works fine. Hope this works for everybody.
4helpful
2answers
Microphone will not pass setup
44helpful
3answers
How can I fix error 1117 problem with speech component. I have tried restarting the browser and the computer.
This will fix IF you are running a personal firewall:
Enable the Rosetta Stone app to communicate within a trusted area. This lets the app send data to the computer that it is running on. An example might be port 127.0.0.x. You can still block it from communicating with the internet if you like.
In my case, I run the Sunbelt Personal Firewall. I went into its configuration panel, clicked on the Network Security tab, and found the Rosetta Stone Ltd. executable entry. Then I ensured that a green "permit" checkmark appeared under the Trusted Out column. Apply and close. Restart RS and the speech component should work.
-Mike
Top Rosetta Stone Computers & Internet Experts
vince
k24674
Vinho Xie
Vinho Xie
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
