SOURCE: air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
SOURCE: Kenmore 90 Series Electric Dryer will not run
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
SOURCE: frigidaire defrost problems
if the heater and thermostat are good and wired correctly then the only other thing would be the defrost timer board.
SOURCE: Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
