SOURCE: pioneer avic z2
The rick to cure this problem is to disconnect the ground wire from the harnessand ground it to metal on the vehicle like ashtray or something. (radio ground to car metal. This will cure your problem
SOURCE: AVH-P5900DVD noise in RCA
there is diodes that you can change to stop the noice or even a capisitor but not fuses. if you look at the capsitors see if the tops of them are buldging or leaking. that is a sign of them being bad and will need to be replaced. the ones you want to look for will be right were the rca's come into the radio from the back.
Testimonial: "woooohh. This kind of repairs is more than i can handle.. I've send it to repair instead, then i'm sure I don't break it. Thanks for your answer.. "
SOURCE: Kicker Amplifier v. Pioneer Head Unit
GET RED POS+ LONG WIRE 2 BATTERY 2 WERE UR AMP IS GANA GO CONECT IT TO THE AMP POS+ (2)GET NEG- WIRE CONECT 2 WERE THE NEG- IS ON THE AMP THEN THE OTHER END OF SAME NEG- WIRE FIND PLACE NEXT 2 AMP WERE U COULD SCREW NEG- TO CAR METL CLOSE 2 AMP (3)GET LONG REMOTE ANT. WIRE CONECT IT TO WERE THE REMOTE ANT CONECTION IS ON AMP THEN SEND IT TO UR PIONEER IS AND FIND REMOTE ANT . ON UR PIONEER HEAD AND CONECT IT SO IT SHOULD BE CONECTED TO UR AMP LAST PART GET THE LONG RC PLUUGS AND CONECT TO UR AMP THEN RUN THEM TO UR PIONEER HEAD WERE THE RC PLLUGS INPUT IS THEN IT SHUD BE DONE!!!
