Garmin Forerunner 205 Gps Training Watch Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The power wont turn on
The power to my forerunner 205 from garmin won't turn on even when I connect it to the power cord.
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 19, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290888
Points
7081
The instructions say that you should "press and hold the ON" button (top left).
Perhaps you are not holding it on long enough (I think that a delay is built into the buttons to prevent accidental operation due to catching it on something).
Garmin 205 and heart rate monitor
What is the problem?
If you are looking for a heart rate monitor, one can be found here.
http://www.gpscity.com/garmin-heart-rate-monitor-with-soft-strap.html
2helpful
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
2helpful
Does garmin 205 have a light up screen for night use?
Yes it does. Pressbutton 1 (top left hand button) to turn on the light and again to turn it off.
If you don't have a copy of the user manual, go to http://static.garmincdn.com/pumac/984_OwnersManual.pdf to down load a copy.
My Garmin 101 won't turn on, even with new batteries. Any ideas?
You said your watch was a "101", I assume that is a Forerunner 101.
The instruction say "press and hold the power button until the welcome page is displayed".
Perhaps you are not holding on to the power button for long enough?
Incidentally, if you do not have a copy of the instruction manual, you can obtain a copy from their web site "garmin.com". "Select support" and "manuals", fill in all three boxes and select your manual from the list given.
1helpful
The watch has been working fine and suddenly will
I would recommend having the charger checked for good electrical flow and I would also have the rechargeable battery inside the watch checked. Even capacitors need to be replaced every so often because they just get wore out. Also, be sure that you arent exposing your charger or watch to extreme temperatures as this will cause problems.
If you have trouble finding a shop that can do this you can contact Garmin support directly at:
1-800-800-1020
or
garmin.com/support
1helpful
I just got a new garmin forerunner watch. How do
Follow this link, give all the details of your device and download it:
http://www8.garmin.com/support/userManual.jsp
If this doesn't work - give us next question.
Rate me, please.
2helpful
The unit does not switch on nor does it show battery charging in progress when attatched to the charger unit
The device may just be locked up and needs to be reset so that it can start up normally. To do a reset on the device, make sure the unit is plugged in to the charging cable/cradle and connected to power. Next press and hold the Mode + Reset buttons at the same time for approximately 10 seconds. After releasing the Mode + Reset buttons, attempt to power the device on normally.
Top Garmin Watches Experts
Sean Wright
Sean Wright
john h
Are you a Garmin Watch Expert? Answer questions, earn points and help others
