Waste ink pad absorber is like a waste tank made of absorbent pads, in here the waste ink is absorbed. In time this waste ink pad will be saturated or full. When it happens the printer will suddenly stop working. The printer needs to be reset to function again and the waste ink pad replaced to prevent flooding of waste ink inside the printer. The waste ink pad is replaced by disassembling the printer.
You don't have to change the waste ink absorber. There are two in the MP150 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
BROTHER 220 INK OBSERBER FULL HOW TO SOLVE IT
