Double check that you haven't inadvertently muted or turned down the effect returns. Also make sure they haven't been inserted elsewhere as they wont work as post effects while inserted into a single channel. If you are using some effects, it will cancel the effect card's ability to use its second channel. (ex. mastering suite)
turn it on and just let it load..it may take like 20 hrs or so but it will come on...and yea when it does you might not have anything that you had on there but you can start over and it will work like new..worked for me
Make sure you are panning hard left and hard right before you export the track. Why don;t you use the roland interface and bypass the mac all together.
Shelly, I have a 2480 but it must be very similar. Import the drum track as a wav file into two of your tracks within the same project. You must make sure the file is a WAV file and nothing else.
Hope it works, on the 2400, I am sure it must since it is a must have.
I have figured out a way to get around this problem without losing your data or sending it to Roland.
I have three roland 2480s and have 4 hard drives. Buy another spare drive and when you load up to a different IDE drive shut it down, then put the old drive back into the unit and it will boot from the last known ide. Make sure it is not the same IDE # that was giving you the problem. You will get at your files but you better start to backup and defrag. I will not delete files on my roland unless I am willing to defrag. Buy an extra drive from a third party. You can see a company that sells this stuff on ebay and they are very good. "VS something store."
