SOURCE: blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
SOURCE: How can turn it on again?
The red phone icon on your phone (end call button) is also your power button. Hold the button down and you should be ready to go. If that doesn't work I would suggest calling your carriers technical support line before trying to fix anything yourself. You could void your warrenty.
SOURCE: Rim Blackberry Pearl flip 8220. Cannot retrive MMS pictures
By retrieve do you mean you have already recevied them and they are no longer visible to you?! If so check the following.
You may have already tried some of these options, but for the sake of completeness.
Check your icons are not hidden. From desktop/ Options/ Show All.
The MMS Data - MultiMedia Messages may be stored along with
your Text messages - check this folder.
Check all your Media folders - including My Pictures and Preloaded.
Failing all of the above - Check MMS in Options and MMS and do the same for Media Card.
If you connect your Blackberry to your PC you will be able to see all stored files and their location..
If you are not able to receive them in the first instance - You will need to enable yout Blackberry to receive them by MMS in Options and checking this option in addition your Network Provider will need to send you settings to store.
SOURCE: Problem with battery/unknown
Your battery might be deffective or your phone keeps sucking any power out of your battery before it can hold a good enough charge I suggest you hook it up to your computer via USB directly and if that doesn't work you might want to look into getting a replacement battery for your phone by either buying it yourself or seeing if your warrenty covers it.
SOURCE: Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
