Panasonic DVD-S53 Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound in DVD player
I have video but no sound when utilizing the DVD player.
Panasonic DVD S53
Kristine
Level 2:
Sergeant:
  • Panasonic Expert 294 Answers
  • Posted on Feb 13, 2020
Kristine
Panasonic Expert
Level 2:
Sergeant:
Answers
294
Questions
0
Helped
171699
Points
904
There are some possible reasons for the no sound issue of player, player audio settings, HDMI cable connection error, Blu-ray discs damage or restriction, etc. If finally, you can't solve the problem, you can try Leawo Blu-ray Player for your urgent need to play DVD.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
422
Points
I have no sound when the dvd is playing
Which type of AC power cord does it use?
AC2-PANASONIC
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/
2helpful
Panasonic cn hds625d dvd sound problem
Try using google translate on the Japanese manual.
2answers
Hi there. i have a panasonic dvd-s53 , the power supply ic1021 is blown up , i need to know the number please. thank you.
I am not totally sure since you may not be able to read the number on the original IC - however C0DACZH00006 appears to be one number for Panasonic IC 1021 reference. (this is for the DVD-S47 but it seems to be standard type for this series).
I suggest you contact an authorised service centre or Panasonic directly, and provide the above number IC to them - along with the DVD player model number - if this turns out to be correct, you can go ahead and order the part. Not too expensive and it is not a surface-mounted component. It is available. I also recommend that you replace all the electrolytic capacitors in the SMPS - as several may have leaked, causing the demise of the IC. Don't just replace the IC - and touch up any dodgy solder joints in this circuit.
See how you go. No power supply is irreparable.
Power will not turn on.
the problem starts from tha power supply main source" or might the plug is damage
Unable to hear voices
unfortunately you cannot hook a dvd player to a receiver, the dvd player has to be hooked directly to the tv.
My RCA high fidelity CD/RECEIVER (Model CR -
The door was pushed in to far you have to pull the door out gently why you pushing the eject bottom.
4answers
Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Daniel
It'll still be 480i, it'll just work on a 1080i input now. You can't make HD out of a non-HD source.
Geno
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
