First thing to check is theat there is no shorts in your speaker cabling either damaged cabling or ends toching together at the amp or speaker connections.
If there is notheing tounching, try unplugginging ALL of the speaker wires then start it up again, if it doesn't click off then carefully check all of your speaker connections. try plugging them in one at a time while turning it on and seeing if it clicks off.
If it isn't a problem you might have a problem in the power supply or amplifier modules of your reciever - That problem would be one for the pros!
Hope this helps!
Good Luck!
Click on the "Start" button.
