The second phone in our Wharfdale atmos twin phone set doent work
The second phone in my Wharfdale atmos twin phone set does not seem to pick up signal from other base unit and so will not maken internal or external phone calls?
The other part of the equation is your source; which is not mentioned in your question.
Your player must also be able to decode Dolby TrueHD and the audio output on it set to Bitstream.
first thing you need to check is the battery as it seems like you have lost charge and it is not recharging and you can order these batterys on line not to exspensive so just undo the back cover and you should see the battery and if you have another handset then take the battery out of that to see if the handset is working fine before ordering a battery
hi, is there network service bar on your phone? if no,check the antenna of the phone if it is properly fix, if not fix properly, then fix it properly. if the problem continue go to your phone menu, go to setting and call setting go to bare calls. if the calls are bad, you deactivate it. if this still continue then you contact your local service provider. thanks for using fixya.
if neither tank is working check the selector switch it is responsible for energizing both fuel pumps depending on the selection, if you have power to switch and power leaving switch than either its lost on the way to the fuel pump or the pump is bad in this case both?to confirm you must check for power at the pump, easiest is the front tank.
