Through the unfreeze you can remove your phone freeze.You can unfreeze your phone by unfreeze code.If you need an unfreeze code visit SuperUnlockCodes.com This service can be used to unlock and unfreeze Samsung mobile phones locked to any mobile network
Don't worry i will help to fix this Phone freeze problem.You can Unfreeze this SAMSUNG Eternity using the Unfreeze code.I would suggest the site MobileUnlockSolutions.com here you can get Unfreeze code and unfreeze it.If the Unlock code does not work ,it's a wrong code.So use correct unlock code and unlock it.Get Correct unlock code for Samsung Eternity phone from the site itself and unlock it easily.You can get Unfreeze code for South American network locked Samsung Eternity Phone .
Because it locked to Network ,you need to Unfreeze it to use other Network Sim card.Otherwise You cannot use other GSM Network Sim card in the Phone,You can get the Unfreeze Code at here Theunlockspot and Unfreeze it...
Sounds like you have a bad solder connection. When you hit it, the connection reconnects until it gets hot again, and then the connection breaks loose again. Probably an easy fix if you have the soldering equipment. If not, you can take it to a local TV shop and they can take care of it for you. Be careful if you repair it yourself. Make sure you turn it off and unlug the power cord. Even with the power cord unplugged there can still be dangerous voltages present inside.
