The burners and its components are totally seperate from oven and there is no controlling shared between them. The problem can be many. Can be the timer control that is locked and not allowing any oven functions. Can be the electricline feeding the oven portion. Can be the oven temp control that tells bake and broil to begin functioning. Can be oven lockout. This is a function that you can turn off by holding the clock or other pad button for 3 seconds. Check your manual to see if I am correct about which touch pad to hold. This is a safety feature that sometimes gets activated and there's no flashing lights telling you about it. Goodluck<Macgivor
Testimonial: "Thanks! The feed back on the "shut down" feature corrected the issue. I held the +/- Min. buttons down for 4 sec. & it shut off & then back on. "
I am not sure if I understand you; did you say the discovery of the shutdown fweature solved the problem? Then you say about holding + & - buttons and it (what is it ?) shut down and then on again. I will help you if you can clarify what you mean, or just tell me that all is ok now. Thanks, macgivor
