I've had a Motorola V276 for several years. It's a good phone except for one very annoying problem. Normally you shut it off, plug it in to charge, and the window reads"Charging" -- no problem. But every so often I'll shut it down as always, plug it in to charge and it powers back up, and the window reads "VERIZON WIRELESS". The only way I've found to corect this is to hold down the "Clear" button for a couple of minutes, and even this sometimes has to be done several times. Any suggestions on why this happens and/or how to correct it?
-Thanks
SOURCE: motorola v3m razr has frozen up
If you have a memory card in your phone, try taking it out and then turning it on. Sometimes if you have to much on your card it will freeze up. Never store anything directly to a memory card in your phone.
SOURCE: Motorola slvr unable to power on
wait until the phones battry get fully chrged working with a fully drained battery is bad to phone as wellas battery itself
SOURCE: Battery Too Dead to Charge?
The issue is probably not the battery but the charging port. I'm having the same issue. I happen to have Motorola Phone Tools on my computer. It works with the W385 but sometimes doesn't recognize the phone. Battery has 2 bars. If I wiggle the cord, it will recognize it. Then 4 seconds later, lose the connection. I already replaced this phone 5 months ago for the same issue.
I think the problem is the charging port is not working.
SOURCE: I need unlock codes for a motorola w385 and v276 can any one help
try the last 4 digits of your phone number
