Find the unlock code for the specific make and model of your
DVD player. Unlock codes for more than 6,000 DVD player models can be
found online at Videohelp.com (see the Resources section).
Write down the unlock code for the make and model of your
DVD player. The unlocking process can be as simple as a short number
code, but on some DVD player models, the code is a complex series of
numbers to enter and buttons to press.
Turn on your DVD player. Remove any DVD that is in the unit.
Enter the unlock code for your DVD player exactly how the
code is listed. On some units, enter the code by using the remote for
the DVD player. On others, you may need to enter the code on the unit
itself or with a combination of the remote and the unit.
5
Turn off the DVD player after you enter the code. When you
turn the DVD player back on, the DVD player should be decoded and able
to read DVD discs from any region.
Find the unlock code for your Sony DVD player model. The DVD Demystifiziert and Video Help websites both provide unlock codes for Sony players that can be unlocked and made region-free. To view the code for your DVD player, click on the model of your DVD player in the Sony hack list on the website.
Perform the tasks included in the unlock code. For most Sony models that can be unlocked, the unlock code is not as simple as pressing a few buttons. You may need to open the tray on the player or power the unit on and off multiple times as part of the hack.
Turn the unit off and then on again after you have entered your unlock code, even if the code doesn't include this step. Once you power the unit back on, it should be region-free and should be able to read any DVD that you insert in the tray.
NOTE: Not all Sony players can be unlocked to be region-free. According to the DVD Demystifiziert page, no unlock codes are available for Sony models DVP-NC85H, DVX-11A, SLV-D980P and SLV-D500P.
Keep in mind that unlocking a Sony DVD player almost always voids the unit's warranty.
To unlock your DV-SL2200W player follow the below instruction. 1. Switch the player on without disc 2. Using the remote control press "HOME MENU" 3. Select "INITIAL SETTING" 4. Select "OPTION" on screen 5. Press "OSD" button 6. Press buttons, 3,5,7,0 7. The player will automatically shut down 8. Switch the player back on Now you player will be Multi Region.
HI, paste link below into your browser and follow the instructions. The unlock code for the 6053 is the same as for the 5931. Simply burn the disc and put it in your player. I used this site to unlock mine, very worthwhile.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
