My canon ir 3300 shows error e-000007-0000 how can i solve this problem
fixk
fixi.g fil
fixing film damaged or fixing does not rotate
thanku ji
Please checke fixing film and related gears.
[email protected]
Just change the fixing film,thanks
Error E00007
My
canon ir 3300 got a problem error code e000002-0000. when mechine
switch off the mechine doesnot come to the original position. it
displays the same error code
PLS TELL ME HOW SOLVE THE PROBLEM SIR
M MAIL ID [email protected]
turn onn the mechine press star button of additional function and press 2 then 8 for same time then press star select copier option then function then clear then err then ok restart the mechine it will work
this is right
E000000-0000 PROBLEM
What solution of hinging problem
Just check out fixing film, fixing gear, pressure roller, and fixing sensors.
Open fuser unit of clean the flim sensor with alcohal or petrol
if problems cant solve change the flim
Try to replace the Fuser Film, Bush (if Reqd), and Clean Thermal Sensors. If the problem continues try to reset the Copier from service Mode, If still not resolved, Clear DC Con and let it reboot.
