I have had this problem with a Fujitsu unit before. If the power is supplied to the outdoor unit first but unit is meant to have power supplied to indoor unit first, outdoor will only stop when power is cut off! In that case, you will have to run the power cable to the indoor unit first and then connect from appropriate terminal back to outdoor unit. (Often the indoor will stop outdoor unit by just cutting the power to it via use of a relay on the pcb.)
