Question about Sony DAV-IS10 System
Connection/sound issues! hi I'm trying to connect the following - Samsung LE40M86BD TV Sony DAV-IS10 Theatre system XBox Elite Sky box (not HD) I can't seem to get the satelite TV thro the sound system?? I'm using a HDMI lead from the theatre system and from the XBox. The Sony system works as I've tested it with a disc. I really don't know what I'm doing!!!
  • Anonymous Apr 24, 2008
    sound not loud unless up to 65-70. unless a dvd in it. echoing with tv sound turn up
    Problem Solver:
  • 13 Answers
The best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Posted on Feb 10, 2008
SOURCE:
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Sound Problem
I'm unclear about the comment"If I play a DVD or net fix through separate box" What do you mean by separate box? Please reply.Be specific about what inputs on the tv and what settings you have check in menu as far a sound id concerned.
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi all, I hope someone out there can help me. Recently bought a new Samsung 46" LCD, I also have a Samsung BluRay player and HD Recorder in one, also have a PS3 and finally the Sony DAV-IS10. ...
It's unclear where the sound is emanating or where it is lost in this scenario or even the type of connection you're using to carry it.
It almost sounds like you're using the TV for sound or it's in the audio path. The sound from any high end source should be processed by the SONY DAV as close to its original device as possible and not unnecessarily patched through the TV.
The TV only NEEDS Video. High-end Audio is wasted on it.
The symptom sounds suspiciously like a loss of data from the source to the Sony DAV.
Please clarify or establish that this does or does not happen without using the remote. Sometimes remote commands are heeded by unintended devices. Try to Pause/Play sequence using front panel buttons on the unidentified Samsung BluRay to eliminate that possibility.
http://www.retrevo.com/support/Sony-DAV-IS10-Home-Theater-Systems-manual/id/2771ag604/t/2/
Observe the indicators on the Sony for any clues when the problem occurs.
Sep 24, 2011 | Sony DAV-IS10 System
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
Hi I have the Sony DAV-HDX285 home theatre system and I'm trying to get it to work with my Vizio 47" HD tv. I go thru the speaker setup with the dvd supplied and all speakers are working tthu the home...
I assume you mean the TV sound only comes out of the TV. THAT would involve internal audio controls at the TV.
Why don't you just connect the TV-related audio directly from each source to the DAV instead of through the TV, which adds NOTHING to the sound quality and may even degrade or limit it.
Aug 17, 2010 | Sony Bravia DAVHDX285 Theater System
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
Connect to comcast HD receiver
use 2hdmi cords -tv to cable box and the cable box to the davis10 than go to the setting on the davis10 and turn on the hdmi
Jan 04, 2009 | Sony DAV-IS10 System
C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Oct 07, 2008 | Sony DAV-IS10 System
Sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
If you need further help, reach me via phone at https://www.6ya.com/expert/abdouramane_7b3aaa187339b631
Jan 17, 2008 | Sony DAV-IS10 System
Sony DAV-IS10 System Logo
336 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
