Turn On- when the receiver start, after 10 sec, he goes in protector mode
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RECEIVER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE RECEIVER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE RECEIVE WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE RECEIVER SEES AN EXCESSIVE LOAD DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
