After completing a wash cycle ( thrugh the spin ), water continues to "drip" into the tub...for varying amounts of time - not extremely long ( but never actually timed the duration ). The machine is seven years old, but the problem has only occurred in the last two weeks ( since the last week in January, '08 ).
Hi there
you can check the connection hose thats directly under the tank. it may be due to time and there may be a crack on the hose. you may readily buy a replacement hose from any malls in your area and you can actually do the replacing yourself. Doing the replacement requires you to tilt or completely flip over the machine to handle the changing of the hose with ease.
hope this helps
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water
when is filling only, check the following:
1.Fill
hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the
following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the
following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Thanks...let me make sure that I get your drift; When you speak of "hose", do you mean the hose that goes from teh awter supply itself to the fitting on the washer, or do you mean a different 'hose' ( maybe something inside the washer's abck bulkhead ? )....
Thanks again....
Hibbingmn
ptwn6050mowt
