Need sylvania tv codes
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
If it takes a 3 digit code try these for a sylvania tv
SYLVANIA 006 003 059 060 063 064 127 160 164 044 249
if it takes 4 digit codes try these
Sylvania 0054, 0030, 0171, 0020, 0096
hope this helps you
I have a Sylvania TV and it won't work with my Comcast cable remote
I have a sylvania lc320ssx 32" and cannot use a universal remote with it,
I had the same problem with Dish Network not accepting a remote code for my Sylvania TV. I tried all codes in the manual and others found on the internet. I found, finally, that code 672 worked.
Never buy another sylvania tv ever.
Factory reset the tv
SOURCE: needed codes for RCA312W to control Sylvania tv sst 4273
code 1192 works using my rca model rcr4358 universal remote with my syvania sst4273 tv
SOURCE: rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
SOURCE: need the tv program codes for sylvania tv. for
Check the attached link it may help.
http://www.jascoproducts.com/support/universal-Remote-codes.asp
have an older sylvania tv/vcr trying to find any device code for ..model src 201 34ac
entered 8 codes from funai and sylvania ...nothing
I have a Sylvania 20" Digital/Analog TV Model # LC200SL8. I want to program the remote for my Direct TV receiver to operate the TV so I only have to use the 1 remote for both the TV and the receiver. None of the codes supplied with the receiver manual work nor do any of the codes that came with a Phillips universal remote I also tried. Also, the code search procedure for both of these remotes (Direct TV receiver and Phillips universal) failed to find a usable code. How can I obtain a correct code for this model of TV?
i to have tried every code
i have a 19" sylvania srt2319 need codes for satelite remote to operate both-whats the code please !!?
Have a Sylvania 13" TV. Can't get the volume to work with any remote. Tried 3 different universals and the one for a cable box. Any suggestions?
I'am trying to program my 19 inch tv. i already tried two universal remotes and none of the vodes worked wat should i do?
have a 13" combo tv/vcr and only the vcr code gave me on/off and channel change and vcr controls. The volume and other menu options do not work. I have an old RCA universal remote so I am going to try an updated one to see if that solves the problem.
i have a sylvania tv and have dish network remote control. i could not find any code that operate my tv from the same remote control
i hve a 19 sylvania tv and have tried two different universal remotes and can not find a code to operate it, do u hve a solution to this problem.
My universal remote works for all tv's except for sylvania, what's going on!
Hey the code for my TV was 030, works the whole remote. Man it sucked figuring that out. Should work for you too. :)
Just got a new 32"Sylvania LCD flat screen (LC320SS9). Dish remote codes to operate TV won't work but can still work satellite (can't turn TV off/on or control volume but can change channel on sattellite). Called Sylvania they suggested Using Funai, Symphonic or Emerson codes. Tried them, still no luck.
Just got a new 32"Sylvania LCD flat screen (LC320SS9). Dish Netork remote codes to operate TV won't work but can still work satellite. Does anyone know the TV codes for this new TV????
Sylvania 42" lcd AND Element 15" lcd tv....Dish Network remote will not work with these tv's...can anyone help??
I also have a LC321SS9 Model 32 inh Sylvania TV. I just cant get nay of the codes to work. No answers are helpful yet
I have cox cable and can not get the cox remote universal code to control the sylvania LC321SS9 tv. Any suggestions are helpful.
I have a Sylvania (SSL15D5) 15" Flat Screen and I cannot find a code to use the Dish remote either.
I have a sylvania lc370ss9 37" and cannot use a universal remote with it, help
I have the same problem. The Comcast guy came yesterday to set up my new HD box (which has it's own remote). The Comcast remote is supposed to operate the TV too. Â None of the codes worked, so I am stuck using both remotes for the moment. Â I may return the tv because of it.
I Have a Sylvania 32" LC321SS9 and can't get a code so I can use my DISH remote.Did anyone get an answer?
I bought a 37" sylvania, and was told by customer service there are no codes; also, told by Cox Cable Tech he had same problem with 4 other sylvanias; customer service told me to try codes for Funai, Emerson, Symphonic and Magnavox; still no luck.
Same problem ! We just bought the 37" flat screen. We can't find a code that will work the volume & turning off the TV without having to use two remotes? Any solutions? Thanks...
I can't program my tivo control to work on this brand new sylvania model lc321ss9 ... I guess the manufacture does not care about customer satifaction .... I will know better next time.......
looking for remote codes for sylvania 42 inchlc420ss8
I cannot find the correct code to program the FIOS universal remote for
my 19" flat screen Sylvania tv. I've tried the 26 codes listed with the
remote as well as stepping the remote manually through the various
codes. Help anyone??
Same problem on my Sylvania LCD320SS8-Comcast remote will not work on this tv. I called and emailed Sylvania and they say they do not support any remote besides their own- essentially telling me tough luck. Makes me want to return the tv, but everything else is good about it. Comcast was no help either-they want to charge me for a service call, but say it will not help-would like to ditch them as well. You would think both companies would have some interest in solving this issue.
need code for remote
Sylvania remote does not work with COMCAST
dish network remote won't work with Sylvania t.v.
I cant switch from input 1 to input 2 I lost my remote and I cant change it from the tv itself so I cant use my DVD or anything else.
I have a very old Sylvania, and after hours and hours of try to program it to a dish remote, I found the code was 756 Bingo! it now works with dish.
