Haier HRT02WNC Compact Refrigerator Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not run at all when plugged in - Haier HRT02WNC Compact Refrigerator
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
558
Points
More than likely, it needs a new control board. It takes about 5 minutes with Google to locate a new board. Runs about $30 (including shipping.
Warning, requires knowledge of soldering to install this board.
No, I had no way of testing the board. However, since the part is cheap and it came up almost immediately when I started searching, pretty safe to assume that's the problem. Yes, replacing the board solved the problem for me.
The control board is located behind the sheet metal on the back of the refrigerator.
I purchased my replacement board through www.repairclinic.com
Item # 1223802
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Jan 16, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409419
Points
5205
Did you pay your power bill // --- ok so lets ck the plud you plug it in for power / try a light . if ok then lok at the connections in back where the cord hooks and ok ( go to cold control . ) turn it off and listen for a click when tuning it on . no click / rwpl control / if your have ohm meter I would test it and make sure it has on & off . if its ok ck the relay on compressor .. . **** hope this hepled . feed back pls ..
I have a 3010 Kawasaki mule it stooped running and I replaced the fuel pump as it did not seem to work I still cannot get it to run right will run on a idle but nothing more
I work on 3000 and 4000 mules at my job. when it runs bad it can be to coil. Each cylinder, which is 2, can be the coil for that plug. What I do is pull the plug on one cylinder. If it crank then I pull the plug on the other cylinder. if it will not crank I know it is the coil for that cylinder.. It might be the plug, change the plug then change the coil and wire.
I hope you know when I pull the plug on one and it cranks and then I put the plug back on for that cylinder and pull the plug for the other cylinder.
Mar 29, 2019 • ATVs
I have a polaris ranger 6x6 500cc the plug in it now is a ngk bkr5e 7938. a friend gave me 2 unused ngk b7e s plugs and said that they wood run fine. Are these 2 ngk b7e s ok or what?
The figure 7 represents the heat range of the plug. Usually it is unwise to deviate from specifications unless problems force choosing a different heat range. If the spark plug regularly fouls then a hotter spark plug could improve the problem - with NGK that would mean moving from 5 to 4.
Any move must be made with care to avoid the engine damage possible if the spark plug is too hot.
Hot and cold plugs, incidentally, indicate the amount of heat the spark plug dissipates from the centre to the body and doesn't affect the temperature of the engine. Broadly cool running engines need hot spark plugs and hot running engines need cold plugs so in each case the spark plug nose will achieve the self-cleaning temperature without becoming too heated.
Moving from a 5 heat range to a 7 (NGK) is moving to a colder plug so yes it will run fine, at least for a while, though you could find plug fouling might be a problem...
Jun 18, 2017 • ATVs
What number plug should I be running in my 2002 125 rm suzuki
I would use a NGK Platinum Plug (R6918B-8 or BR8EIX/BR9EIX) and try to cut back a little on the oil mixture to gas ratio or adjust the gap a little hotter.
3answers
Plug fouls out turns black and starts to backfire
What does the oil look and smell like? Also what conditions is it been ran in lately, and what fuel are you running?
1helpful
Husqvarna 128ld backfires misses but if you put a ignition checker inline with plug it runs ok
sounds like you have a poor connection from the terminal lead to the plug. When the lead is plugged onto the plug it isn't connecting right and when you put the tester in line then it connects correctly at both ends
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Yamaha 1998 25 hp 3 cylinder outboard pistons hitting spark plug
This must have the wrong plugs in the motor.The gap between the top of the piston and the plug is about 8-10 mm.No motor will run with any bearing that is that worn.You said you looked at the top of the piston.With the head off,did you check how far the spark plug extended through.The reason being,is that it should not protrude all the way into the combustion chamber.It must have the wrong length plugs in it.If it runs well,you have the heat right.Mate.Hope this helps
What Spark plugs to install?
yes the 8 is the hotter plug just for giggles how do you know that it's running lean? have you had someone put it to the 4or5 gas analyzer, NOT A DYNOJET DYNO? it's the only way to know for sure and by how much. the reason i say not the dyno-jet is because of the fact that it uses a wide band 02 sensor which in this case only gives a limited amount of info versus the 4gas. some people have said the hotter plugs has run better for them, but i can'tconfirm. i can confirm that i hadn't noticed much difference between the Iridium plugs and the stock. no improvement on the dyno and nothing really noticeable anywhere else. for the price of stock NGK's thats what i would stay with. marco,,,
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
