Contributor
- Posted on Nov 13, 2012
Re: How does the gear box come apart on a six horse troy...
- Remove belt guard on left side
- Remove belt, large pulley on gearbox.
- Remove throttle cable, idler pulley cable and shift handle.
- Remove engine, handle, wheels, tines cover and tines.
- Lay gearbox on side on two sawhorses, left side facing up
- Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
- Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
