inverter is bad..
if screen has a little white 2 pin jack, which plugs into a little board
then its that little board is bad .if it has one gold jack
alone and plugs in at bottom of screen , then its screen bulb bad
new screen !!!
either you have the video setting of the television set to wide screen or you are purchasing "WIDE SCREEN" format dvds instead of "FULL SCREEN" format dvds
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
v1 is your verticl scan has stoped for a reason,akb 1 is the feed back from the crt to the video ic, hv 1 is high voltage stop the set ,clear the error codes and start again record them and conpare the results for the true fault.
Greeeting from Belize you are having a problem either with cold solder or a problem in the power supply those lines are hum bars due to a defected filter cap.resolder your power supply if that does not solve the problem then you replace the power supply you can get a power supply kit from www.dalbani.com in florida.good luck.also make check in the vertical section if you cannot do it your self take it to a qualified tech to resolve your problem this should cost you about $75.00. to get it fix.
