Kenmore Elite HE3t 11042922200 Front Loading Washing Machine. the washer makes bad noises when it goes to 1st rinse and spin cycle, stops and says F02 - (Drain Problem) Door is locked and will not open. If you wait a while, unplug and plug back in the spin cycle will work and the door will open. The unit is about 7 years old.
Thanks
I have one of these units and the first time the pump acted up, I opened it to find a sock had worked its way inside. The second time it happened, the outside drain had froze a bit in the cold weather prohibiting any draining. The last time it happened two days ago the pump finally quit working and I installed the new one I had previously ordered when I thought it was something else and it has solved the problem. My unit is about the same age.
