Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
SOURCE: dishwasher running on cold water
that will be the callrod heater at the bottom look at it in the bottom to see if you see any cracks
not an easy job
SOURCE: Water not heating up in dishwasher
Make certain that the water supply is connected to the hot water valve. You may have an issue with the heat element or thermostat (if applicable). Contact an appliance service company.
SOURCE: Dishwasher not heating Zanussi
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
lmnbv
SOURCE: My zanussi dishwasher, zdf 301
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
