I think you may want to see this Frequently asked question regarding using MagicJack overseas.
Can I make calls to countries outside the US and Canada on magicJack?
You may be getting the verify your Login message, because according to their knowledge-base, to call from another country outside of the US and Canada, you have to actually prepay for to use International minutes with MagicJack.
This may be why you are not getting the connectivity to place your calls through the MagicJack from within England. Take a look at that link.
-Mactechtrainer
magicJack works hard to ensure a clear connection.
If you experience an "echo" when using a magicJack on a computer:
In order to receive calls, you must turn Notifications on for your magicJack APP.
On your softphone, please do the following:
If that does not work:
<Requires some technical understanding. Explanation below. >
Now restart your magicJack, by following the steps above.
For error 1
If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
To resolve this, make sure that one end of the ethernet cable is plugged into your modem/router/switch and the other end into your magicJack.
You also need to make sure that your modem/router/switch is powered on and that the port you have connected the magicJack to is functioning correctly.
MY PHONE ALWAYS EVERY DAY SAYS ERROR 3002 CHCCK INTERNET CONNECTION , & IT'S NOT THAT. RIGHT NOW IT'S DOING IT
