Motorola Satellite 9505 Cellular Phone Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have no signal recieved from our sky satallite
Fiuciuc Andrei Nicolas
Level 2:
New Friend:
  • Expert 89 Answers
  • Posted on Jan 15, 2010
Expert
Level 2:
New Friend:
Answers
89
Questions
0
Helped
169808
Points
217
I don't recall if that phone had an external antena but you should check if it is well mounted,if it is not dammaged,rusty and if it had an internal one check for no oily stuff inside. If the antena is not the problem try contacting your operator and ask them if they suport such conectivity since direct satelite connection is expensive!
Will clock signal stay on when the clock recieves it
If this is an atomic clock. I have a sky scan and as soon as it gets its signal,it will be ok. God-Bless!
Jan 01, 2018 • Home
1helpful
2answers
No signal being recieved
Sure the sat is getting power?
1helpful
How do I pick up a satallite signal for my GPS?
it needs a clear view of the sky from the vehicle lots of trees or buildings can block the signal
Feb 21, 2011 • GPS
My navman navigator not getting gps signal
These are the following things that needs to be checked if you dont recievet he GPS Signal, They are as follows
1) Check BAUD rate and PORT of your Device
2) Ensure battery is fully charged ( AC or via USB) prior to use. lesser power gives you poor gignal recieving ability
3) ensure clear view of the sky, if the sky is cloudy you wont able to recieve the signals
4) keep away from mobile phones or other electronic items since they cause interference.
5)There could be damage to the SIIRF chip because you have it plugged into car power when starting engine.So always switch off the device while powering on, If the SIIRF Chip is failure, then you need to replace the chip..
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
No signal
make sure it has a good view of the sky and let it aquire the satellites for a while. It may take sometime for it to figure out it's location once it starts seeing the sats. if you have it in a car, try another location. on the dash up near the window is a good spot for it to receive signals.
Nov 10, 2009 • GPS
Onn 32 hd ready tv will not recieve hd signals.sky installer tried for 4 hours but could not get it to work.the sky + box works ok but sky hd did not
you havent got another channle sitting on top of your hd channel have you . also is the hd cable pushed in all the way.
Can't get satallite channels
If you are on Satellite then it only works off of channel 3 and you will not get any other channel on the tv set. But you will need to turn your sat box remote to change channels.
Sky+ satallite receiver
You can find out if the remote is broken by taking a camera4.gif with an LCD viewfinder (such as a camera phone1.gif) in a dark room, point the remote at the camera and in the viewfinder you will see a light coming from the remote if it is working. If you see a light, chances are the remote is good. If not then the remote is more than likely bad.
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Top Motorola Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
