Pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Got to the Seiko web site (Seiko.com) and select "products" from the menu bar at the top of the screen.
On the next screen you will find a blue box in the left hand corner of the screen labeled "instructions how to use your watch". Select this and enter the watch identification information to obtain the manual for your watch.
I have a Seiko F1 Honda Sportura chronograph
To set the alarm follow my instructions
pull the crown out 2 clicks set the alarm the same as the time shown on your watch with the lower button ( or alarm button ) ....push the crown back 2 clicks than pull 1 click out ....set the alarm to the desired time than push back 1 click ......now the alarm is set
or go to this addres
1: http://caliber.seikowatches.com/
2: choose desired language
3: select alarm chonograph and play the alarm option
Hi
see also :
Vintage Seiko G757 CITIZEN Ana Digi Temp
Best
SOURCE: How to adjust alarms
Setting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
