I have broken the glass top on my GE electric cooktop. The model number on the bottom of my unit is JP340B0A2 BB. None of the internet links recognize that part number. I need the part number of the glass top and the cost. Can anyone help? my e-mail address is [email protected]
I have broken my GE electric cooktop. I am trying to identify the glass cooktop part number. My GE unit has a part number JP340BOA2BB. When I make a part number input to the internet links for parts, they do not recognize the part number. I need to find the glass cooktop part number and also the cost. Since my unit is 10 years old it may be more economical to just buy a new unit instead of replacing the glass cooktop. I hope this helps and many thanks for responding to my input.I have broken my GE electric cooktop. I am trying to identify the glass cooktop part number. My GE unit has a part number JP340BOA2BB. When I make a part number input to the internet links for parts, they do not recognize the part number. I need to find the glass cooktop part number and also the cost. Since my unit is 10 years old it may be more economical to just buy a new unit instead of replacing the glass cooktop. I hope this helps and many thanks for responding to my input.
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link http://www.bosch-home.co.uk/store/spareparts/search
GLASS MAINTOP ASSY Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
http://www.appliancepartspros.com/modeln...
