Epson Stylus Photo R1800 InkJet Printer Logo
Posted on Feb 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing B&W, then and now...
I have been using MIS carbon inksets with great results, untill recently. I Have been printing with the black only option. This past week I printed a dozen color prints. When I went back to B&W printing all I can get are brown/sepia toned prints. I am printing on Epson scrapbook paper.
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Feb 12, 2008
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
64113
Points
121
Try do do print head cleaning
what windows version are you using?
3helpful
Printer does not print documents. Model IP3000 pixma. Approx 3 years old, used in my classroom. Printer has been working well until this morning. This is a sudden failure. Performed all maintainence with...
I had this very same ongoing problem with my iP3000 and recently with my iX4000 but I refused to believe it was the printheads as the iP3000 would print cd/dvd discs without a problem. Colour on paper was always there even though I used Calidad tanks.
My solution, or more aptly, my workaround was to change the paper setting from Plain paper to Glossy paper but still using plain paper and low and behold, after nine months of test pages with only the Windows logo it stated printing black text again albeit slowly now. Same deal for the iX4000, it started printing black text on plain paper as well after 4 weeks when the problem first occurred
I also did all the maintenance rigmarole over and over etc...with no results. My printers are hooked up to two PC's, Vista and XP so maybe I eventually scrambled the printers barins or something, anyway I'm printing again.
Worth a try and nothing to lose
Trying to print in black & white only
THis option is in the printer driver.
under Printing Preferences
Graphics
Output Color
Change this to BLACK
4helpful
2answers
Epson 1400 Printing Orange colors Green
The problem can be two fold. Wrong cartridges, or blocked/damaged inkjet openings. Return it to the seller under warranty if its brand new. If it was fitted with non epson cartridges your warranty may be in question.
But I could almost guarantee the black qand the blue cartridges are faulty or their feed jets are
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
2answers
Epson Stylus CX4700
Hi , in epson product are good the problem is the head are easily clug by ink , the pinter need to check nozzle it can be determine the head need to clean printing result of check nozzle , if the result blank or small printing result , the head need to clean thoroughly it may consume 1/2 of the full tank ink , until the printing will clear and bold letters black and color.
DVd label
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
1helpful
Printing result pour
Is the cartridge gen HP cause this will most likely be your problem if not slight slight chance it could be fuser but I would recomment replace toner/drum cartridge
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
