The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here:
http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity,
http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
yes, vista. please help!
I keep getting this far but i don't have a registration number because my original box with software etc was stolen about 5 years ago. and i have no way of getting the receipt or anything. I only got the chance to use the thing twice! please help me. I purchased it from CompUSA of Greensboro some years ago.
I can not get my computer which is running Vista to recognize that I have plugged in my inport deluxe audio recorder. Please help!!!
I was moving and lost the cd sleeve that the registration key was on I spent 80 dollars on this at comp usa, and I barely got a chance to use it. can you help me?
had to restore computer and lost install disk
I had to restore my comp. and now that I try to install my Xitel I can't find the activation code and I do not have my receipt anymore. Can someone help me please if possible. Thank you. Gil G.
Hey there roseecm. Which operating system are you using? If it is Vista, let me know and I will help you with the Updates needed.
