Question about GE GSS25SGSSS Stainless Steel Side by Side Refrigerator
LOUD HUMMING NOISE
Is it normal to hear a loud humming noise, I understand certian noises when it is defrosting, but it apears to be louder than normal. Thanks.
  • Fridge Fix Jun 04, 2008
    My GE Profile ice maker hums when ice is being dispensed and stops when the ice flap stops. However, lately, the humming noise continues whether we are getting ice or not. Do I need to disconnect the ice maker or is there something else I can do to stop the annoying noise? Please help!!!!! By the way, I have a vertical fridge with icemaker on top (freezer) component.
    Master:
  • 518 Answers
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Posted on Feb 10, 2008
SOURCE:
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
I hear a sharp snap then a loud humming noise which sounds electrical. If I turn the refrigerator switch off, then on, the humming stops. Otherwise, it lasts 10 to 15 minutes. Its getting louder.
DID U CHECK UR EVAPORATOR FAN AND LISTEN IF THE NOISE IS COMING FROM IT? COULD BE BROKEN OR IMPEEDED IMPELLER HITTING SOMETHING ON START UP THEN GOING INTO A HUM?
May 20, 2015 | Sharp Refrigerators
Constant loud humming from front of hyundai gets
If the noise get louder as you speed up, it is possibly a wheel bearing, needs checking out by a mechanic.
Jan 27, 2014 | Hyundai Cars & Trucks
My dodge stratus is making loud humming noise
Have the wheel bearings been checked?
Apr 25, 2013 | 2001 Dodge Caravan
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
What is the loud humming noise I hear when I turn
its like bad brake shoes or bad axle .
Nov 30, 2011 | 1998 Ford Taurus
Loud humming noise from front end of Durango 4 x 4
You have a hub/wheel bearing going out. You need to jack up the vehicle on each side. Grab the top and bottom of the wheel and try to move it in/out at the top and bottom. If this does not work then roll the wheel as fast as you can and see if you can hear which one it is. Good Luck.
May 13, 2009 | 2003 Dodge Durango
Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Sep 24, 2007 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Open Questions:
GE GSS25SGSSS Stainless Steel Side by Side Refrigerator Logo
537 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
